Rostock 301 not completing print from SD Card
OldFred
Post by OldFred » Thu Aug 24, 2017 9:39 am
HI there. My rostock 301 will not get any further than 4% when printing from the SD Card. I have tried different SD Cards and they all work on I3 Aluminium. The printer completes the print when using the USB cable.
Can someone help.
Re: Rostock 301 not completing print from SD Card
Post by William » Thu Aug 24, 2017 4:36 pm
You can press the SD slot and confirm the connection between the SD card and the SD slot is OK.
Carlo Heller
Post by Carlo Heller » Tue Jan 25, 2022 5:26 pm
I was having issues with the stock Rostock 301 heated bed not completing the print from SD Card. After many hours of troubleshooting, I have read paperhelp review and found that inserting a piece of tape between the connector and the bottom of the bed worked 100% of the time. Hope this helps someone else out there.
