Double extruder on I3 pro w
hi everyone .... can i install double extruder on my I3 pro w printer with 3d touch sensor? If yes, which firmware should I install? or is it enough for me to modify mine for the double extruder?
Re: Double extruder on I3 pro w
Hi, If you want to change to a double extruder,
Can refer to pro c,
viewtopic.php?f=13&t=17887
Then flash the firmware of pro c with 3d touch.
You can refer to: viewtopic.php?f=13&t=17517
Can refer to pro c,
Thanks ... I'll try it as soon as possible and let you know ...
Thanks for the advice given to me ...
this is my printer built with double extruder ...
calibrated and functional ...
[img]https://ibb.co/tLNXs29
Thanks again...
Roberto
Thanks again...
Roberto
