Which one should I buy? A10m or Prusa I3 dual extruder
mikelo74
Post by mikelo74 » Sat Aug 24, 2019 8:24 pm
Hi.
This is my first post.
I´m Miguel from Spain and I want to buy my first 3D printer.
I know design in 3D and i was "trying" the Cura.
I want to buy the 3D printer to print in ABS basically, but i want print complex 3d models, so i need print supports in Hips.
Which one is the most recommended to print with supports?
I know the Prusa I3 have a bit less print area, but not much, and is not a problem if is better this.
Thanks a lot :D :D :D :D
Re: Which one should I buy? A10m or Prusa I3 dual extruder
Post by William » Mon Aug 26, 2019 9:45 am
Hi, For support you can add it in the slicing software to view it.
If you need to print a larger model, it is best to slice it and save it to the SD card for printing.
earlparks
Post by earlparks » Thu Dec 05, 2019 9:45 am
I wonder the same, any idea?
Jarda3d
Post by Jarda3d » Sat Dec 07, 2019 9:51 am
ABS plastic is not easy to print, it does some strange behaviors and you could think that your printer is total crap...
DID NOT BUY PRUSA! Their printers are only for those, who want to learn about all printing problems which are more than 10 years solved with other mechanical constructions of printers.
See here: viewtopic.php?f=66&t=69444&p=103207&hilit=prusa#p103207
A10 Slic3r profile: here
