restore failsafe was accidentally pressed.​(i3 pro b)
devildoll0
Post by devildoll0 » Sat Oct 10, 2020 8:08 pm
I have a problem
Home Auto (1mm move)
x, y, z are initialized
z moves too much at once.
x, y +200 or more keeps running. It is stable up to 190.
Stable up to z +30.
More than that, x,y,z all hit the wall.
What settings do you need?
i3 pro b
The z axis is too much of a problem.
If you move 1mm
Moves in 10mm increments.
Jaden Raynor
Re: restore failsafe was accidentally pressed.​(i3 pro b)
Post by Jaden Raynor » Fri Jun 24, 2022 3:21 pm
If you accidentally restore a Failsafe you can still continue using your device. However some features may not work properly or may be unavailable. For example if you accidentally restore a Failsafe while your device is encrypted you will no longer be able to decrypt your device. You can also get economics dissertation help online which is very important in this scenario.
