gcode end
tuskman
gcode end
Post by tuskman » Thu Jan 05, 2017 12:10 am
Hi.
I have a G2S pro and a Rostock 301 and the command
G28 X0; Home X axis end-of-print causes the printed parts to be dragged into G2S PRO and into Rostock 301 as it executes X0 first.
bang
Re: gcode end
Post by bang » Thu Jan 05, 2017 9:50 am
tuskman wrote:Hi.
Did you use Easy Print or Repetier Host?
I guess you add "G28 X0" in "End Gcode"?
Actually,we add "G28" command in "End Gcode" generally not "G28 X0" for Delta printer.
tuskman
Re: gcode end
Post by tuskman » Thu Jan 05, 2017 12:54 pm
I use both and the bug is in easy print. At the end of the printout, it first makes X0 and then G28. I say it because it first goes to the x-axis and then goes home.
thanks.
Re: gcode end
Post by William » Thu Jan 05, 2017 2:15 pm
Thanks for your feedback,we'll check it soon.
Veenoh
Re: gcode end
Post by Veenoh » Thu Jan 05, 2017 2:26 pm
Actually, the main problem is in the printer firmware, at least for the 301. Delta printers are supposed to ignore the x y and z flags in the G28 command. Geeetech tech support is aware of the problem and has said their engineers will fix it in the next release.
Przepka1985
Re: gcode end
Post by Przepka1985 » Tue Oct 27, 2020 2:51 am
tuskman wrote:Hi.
Use G27 P2
Nozzle will get away from printed item.
Remove all movement co and like G1 from end gcode.
Leave turning heater and bed off, and fan up to you.
