Can't select printer
Veenoh
Post by Veenoh » Fri Dec 30, 2016 10:56 pm
Looks like a good start at an easy to use printer host/slicer.
When I select a different printer in the config dialog, the selection keeps going back to the MeCreator 2 as soon as Apply or OK is pressed.
Edit: it works when I "Run as Administrator". I think access is being denied to the Geeetech folder in Programs(x86).
Admin
Re: Can't select printer
Post by Admin » Wed Jan 04, 2017 6:40 pm
Veenoh wrote:Looks like a good start at an easy to use printer host/slicer.
Thanks for your report, we will check and fix this bug soon.
macinblack
Post by macinblack » Mon Jan 09, 2017 7:58 pm
I can't change too... please fix it
Post by William » Tue Jan 10, 2017 5:57 pm
Hi,@macinblack
First run easy print as administrator,then try install it on other Disk not Disk C.
