duplicator 5 problem
monhe
Post by monhe » Wed Feb 24, 2021 9:55 am
I have a problem with my duplicator 5.
I just assembled then and now the Y and Z are flipped... causing the motors to keep turning.. even when reaching the end..
The X axis, it has a direction from left to right and when it reaches the end it stops and walks a little backwards (I think that is correct).
The Y Axis, moves from the back to the front but when reaches the end , the motor keep turning, i need to use the "emergency stop"
The Z axis moves Up to Down and didnt stop too, i need to use the emergency stop.
At the beginning, the Z and Y axes had the opposite direction, but I installed the "duplicator" firmware and changed the directions of both axes.
What can I do to correct this problem?
Thank you for the help,
