Post
by _kaktus_ » Tue Dec 25, 2018 4:11 pm
Hello.
If your sensor is supplied with 5V DC voltage, a voltage divider on these
(R1 R2) resistors
is not required.
The main µC on the controller board is also powered by 5V DC voltage.
In this case, the voltage range at the output of the sensor is compatible with the voltage range at the µC input.
For verification you can measure the sensor output voltage before resistor R
1. Black wire.
