Something you need to know before using 3D Touch
NicoFR
Re: Something you need to know before using 3D Touch
Post by NicoFR » Sat Mar 04, 2017 11:07 pm
Thanks for all your tips ! Still remaining one issue in my case.
In the wiki, it is mentionned :
"From the display go to Menu and then Prepare/Move Axis/0.1mm/Move Z"
"Now move the Z axis slowly down..."
but I can only move it up in this case, either using Repetier.
Do I also need to tweak some other files in the firmware ?
--> Ok modified this to allow movement over the HOMEPOS:
Code: Select all
#define min_software_endstops false
DoubleK
Post by DoubleK » Wed Aug 02, 2017 3:36 am
My setting have no function.
//#define Z_PROBE_OFFSET_FROM_EXTRUDER -3.24 in the config.h
M 851says Echo:Z Offset -3.24
but the nozzle is to far from the bed. the distance does not change after modify the config.h
Lellos72
Post by Lellos72 » Mon Jan 06, 2020 8:45 pm
I have the same problem, is it possible that nobody has the solution?
Post by William » Tue Jan 07, 2020 9:21 am
:D Hi, When you adjust the z offset
Need modifications to you,
Save it.
You can refer to this specifically: viewtopic.php?f=27&t=18371
