Page 1 of 3
Z Wobble Fix For Geeetech Aluminum Prusa I3
Posted: Wed Mar 30, 2016 9:18 am
by Mark
Hello everyone! Today I want to share a brilliant idea for the Z wobbling problem from Jimmy Shaw's Tidbits.
Actually it is a set of Anti-Wobble Brackets for the Z axis, it will greatly reduce the lines around the printed object.
Let's see what's it looks like and how it's assembled:
- assembled.jpg (385.31 KiB) Viewed 45499 times
- assembled0.jpg (225.26 KiB) Viewed 45499 times
And this is the result, really quite good!
- Results.jpg (262.75 KiB) Viewed 45499 times
If you are interested in printing a set of these, you can find the file on Thingiverse at :
http://www.thingiverse.com/thing:1424358
In addition, you'll gonna need 2 standard M8 Nuts, they are available at most Hardware Stores. And that's all you need.
Here is this awesome vedio link:
https://www.youtube.com/watch?v=mYswkbC ... e=youtu.be
Also you can learn how to level your heatbed with a piece of paper here.
- QQ截图20160330090837.jpg (470.16 KiB) Viewed 45499 times
- bed.jpg (461.03 KiB) Viewed 45499 times
Thank you for watching!!!
Re: Z Wobble Fix For Geeetech Aluminum Prusa I3
Posted: Thu Mar 31, 2016 5:01 pm
by UndCon
I just built a Acrylic i3 and my threaded rods are really bad. 1 of them wobbles 15mm at the top.
This mod will help reducing lines, but as the rods are so bad I'm going to buy new ones from my local HW store where I can pick any I want from a large pile so I can be sure they are straight.
Great mod - 1st things to print for me.
Posted: Sat Jul 30, 2016 1:08 am
by chase
This is shown with the all metal carrier. And using an 8mm nut on the threaded rod.
Has anyone tried it with the printed carrier?
How much build area height do you loose after install?
Thanx
- chase -
Posted: Sat Jul 30, 2016 1:28 am
by UndCon
Hi, mine is all metal, I Didn't loose much, I can measure when I get back home from vacation
Posted: Wed Aug 31, 2016 5:16 pm
by BlastF
Is this good also for the acrlyc I3? I think i have the same wobbling problem
Posted: Wed Aug 31, 2016 5:25 pm
by UndCon
Hi!
Yes it is!
I also have the acrylic version and this solution isolates the entire structure from wobble. In my case the threaded rods was really bad so I replaced them with straight ones from a local HW-store.
Make sure you enlarge the hole on the top plate to allow the threaded rods to move back and forth.
It is very difficult to mount the threaded rods to center with the couplings, this adds upp to some wobble as well.
All in all - this solution solves it.
//UndCon
Posted: Wed Aug 31, 2016 5:48 pm
by BlastF
Thanks UndCon! I'll print this later and see how it goes
Posted: Wed Aug 31, 2016 5:53 pm
by UndCon
Good luck!
I was so happy with this fix that I printed the parts again after I put the pieces on the printer. The 2nd run was a great.
Posted: Thu Oct 06, 2016 3:52 am
by solder_guy
I am in the process of building the Alum PRUSA, would someone please print these for me so that I don't have to unburied and rebuild ..
Rob
Posted: Mon Oct 10, 2016 12:43 am
by UndCon
I'm printing 2 for you
About 50 minutes print and2.5 Meter filament
//UndCon
