Auto-leveling GT2560 Proximity wiring
RMT
Post by RMT » Thu Oct 01, 2015 9:31 pm
Has anybody wired a standard inductive proximity switch to the gt2560 main board, I couldn't find much info on the pins other than the picture that just shows where everything plugs in.
I understand with a regular switch it doesn't matter which way the wires connect, but what about when wiring the proximity switch ?
The black and the blue wire would it matter, or can I change / setup in marlin firmware how ever I connect them.
ezrec
Re: GT2560 Proximity wiring
Post by ezrec » Wed Oct 07, 2015 3:00 am
The underside of the GT2560 has the pinout for each connector - flip your board over to find out.
Assuming that you will be using the Z-Min endstop, the edge-most pin is marked 'V+', the middle pin is marked 'SIG', and the innermost pin is marked 'GND'.
If your proximity sensor uses 5v power, connect:
Sensor 5v -> Z-Min V+
Sensor OUT -> Z-Min SIG
Sensor GND -> Z-Min GND
If your sensor uses 12v, and has a floating OUT which is tied to GND when triggered, you will need a spare wire to the '+' side of DC IN:
Sensor 12v -> DC IN +
Try the 5v solution first, if you are unsure.
RMT
Post by RMT » Sat Oct 17, 2015 8:48 pm
Great... Got it working.
wayne
Post by wayne » Mon Nov 30, 2015 5:31 pm
Can someone teach me how to wire the 12v input of the proximity sensor on the GT 2560 main board?
:mrgreen: :mrgreen: :mrgreen:
gonilsen
Post by gonilsen » Wed Dec 09, 2015 11:58 am
Then it has to a NPN sensor, if the signal from the sensor shud be - ?
ezrec wrote:The underside of the GT2560 has the pinout for each connector - flip your board over to find out.
