Problems with printing PETG
Posted: Tue Apr 02, 2019 9:30 pm
Printing with PLA or ABS I already have good experience in with my two printers (A10 and A10M). So I thought lets make some tries with PETG.
But against ABS, the first results with PETG were cruel.
I use simplify3d for printing. So here are my settings:
Printer: A10
Temperature: 235°C (230°C-240°C according to the manufacturer)
Bed: 80°C (80°C according to the manufacturer)
Cooling: 0
Default Printing Speed: 45mm/s
Outline Underspeed 50%
Solid Infill Underspeed 80%
Support Structure Underspeed 80%
X/Y Axis Movement Speed 60mm/s
Z Axis Movement Speed 16,7 mm/s
Retraction Distance 4,00mm
Extra Restart Distance 0,00mm
retraction Vertical Lift 0mm
Retraction SPeed 30,0 mm/s
Nozzle Diameter 0,40mm
Extrusion Multiplier 1,00
Extrusion Width 0,40mm
Layer height: 0,15mm
Printing the first layer seems to be ok. But then it looks like the speed is geeting up much faster than the 45mm/s. Especially when printing/filling small areas it feels too fast. The result you can see on the photo. It seems like not enough material is coming. So I tried to raise the temperature in steps up to 250°C. But the results are the same.
I'm at a loss and hope someone can help here.
Printer: A10
Cooling: 0
