XY axis angle calibration?
tanakas
Post by tanakas » Thu May 04, 2017 5:37 am
I have a Geeetech i3 pro b, and the X and Y axes are not perpendicular.
I was not successful in correcting it mechanically, because the Geometry (basically parallelograms) is not very suitable for angle corrections.
Before I start drilling and sawing: how do you effectively calibrate the XY angle?
Also, I was not successful in finding software-based calibrations (like with the Original Prusa i3 mk2). Is there a possibility in Marlin?
Re: XY axis angle calibration?
Post by William » Fri May 12, 2017 4:50 pm
Hi,could you show some pictures or videos about the X,Y axis?It will more helpful for me to understand.
silviop
Post by silviop » Thu Mar 08, 2018 5:10 pm
Same thing here , i buy i3 pro b and if i print square became parallelogram (about 1mm every 10cm).
there is no way to correct mechanically i think to print a front support with smooth rod holes shifted to compensate this angle.
bjoern
Post by bjoern » Mon Mar 19, 2018 8:03 pm
I have the same problem -> 2.5mm every 150mm ... I have no idea how to fix the problem on my hardware.
Yesterday I wrote a little java programm, that correct the y-values in my exported stl-files.
With this workarround I can get acceptable prints.
The programm determines the lowest x-value in the stl-file and calculate for every vertex in relation to the lowest x-value an y-offset.
If you need. I could provide the code.
best regard
bjoern
Post by _kaktus_ » Wed Mar 21, 2018 12:32 am
Gentlemen, did any of you try to correct the number of steps for 1mm stepper motor?
After all, this is the basic calibration of the printer.
