Hi there,
What causes the nozzle to be too high when printing the perimeter.
Ive leveled the bed and when the printer starts it seems sometimes its too far away from the bed.
Any ideas
Peter
first layer printing
Re: first layer printing
Hi,tassat01 wrote:Hi there,
Any ideas
Peter
It seems like you may not level it well enough.So,try to level it again and make sure the room is the thickness of a A4 paper.You can refer to the following words:
1.Set Z axis to initial position
2.After unlocking the motor, manually move X axis and Y axis, and move the extruder to four corners of the heat bed in turn. Because of former rough adjustment, the extruder head is very close to the heat bed.
3.Put a piece of flat A4 paper in the inter space between extruder head and heat bed, then drag the paper to test if there is a slight resistance. If there is, it means the extruder head is already at the right position. If not, you need adjust the screw of this corner of the heat bed to slightly raise or lower the heat bed.
Good Luck
thanks again
ill double check again to be sure its level. Im sure i did check and found that the head was about 1mm away from the print bed
thanks
Peter
thanks
Peter
