NEWBIE: PROBLEMS PRINTING ASA
Bear76TR
Post by Bear76TR » Tue Oct 03, 2017 8:41 pm
Hello everybody
I have great problems in printing some solar shield plates for my weather station with my I3 Pro B. I tried to make them using FormFutura ApolloX ASA filament, as it is a weather-resistant plastic.
The main problem is adehesion of the first layer to the heatbed: i tried a lot of settings (extruder between 235 to 260 C°, heatbed between 70 to 105 C°)
printing speed (from 20 to 70 mm/s) print adehesion help (paper tape, Printafix spray) and slicer (Cura, Repetier Host, Matter Control) but there's no way to keep first layer stuck on printbed.
The second one is warping: one of numerous trials the filament has stuck to paper tape, but proceeding with printing the external BRIM and the support material started to warp and detach from the printbed so i must stop the process
I don't have a nozzle blower fan and i've kept windows and doors closed in my printing-room; my noozle is 0.35 mm
I've also tried to increase extruding width to 130% and extrusion multiplier to 1.2 as suggested by MatterControl
I'm frustrated......
Can anyone help me suggesting some tips or tricks?
Re: NEWBIE: PROBLEMS PRINTING ASA
Post by William » Thu Oct 05, 2017 10:58 am
I think you should set the temp as the filament temp. And maybe you can add a fan?
Bear76TR
Post by Bear76TR » Thu Oct 05, 2017 4:14 pm
Hi William
I've tried multiple temperatures settings in the range suggested by the manifacturer but the filament seems too strong to stick on the printbed
Do you really think that a fan will be helpful?
Have you printed some objects in ASA?
Personally at present i have employed only PLA (without problems) and PETG (a little more complicated than PLA)
Post by William » Fri Oct 06, 2017 2:10 pm
Maybe you can contact the filament seller and let him tell you what you should do.
Bear76TR
Post by Bear76TR » Fri Oct 06, 2017 5:43 pm
I've written to FormFutura customer service and they told me that optimal temperatures are 245/80°, suggesting to use a Printafix-like spray (done without results)
Now I want to try using vynil glue spread on printbed
Yesterday i've printed the same object in PLA and it is almost perfect....
Post by William » Sat Oct 07, 2017 11:27 am
Happy for you!
