Works wrong I guess
indy
Works wrong I guess
Post by indy » Wed Mar 29, 2017 12:37 am
Hi. Can somebody help me ?
It seems something is wrong because when I try to Auto Home it goes to wrong side I guess what makes not good noise.
Check some video: https://www.dropbox.com/s/i79605yp7ihin ... 1.mp4?dl=0
What could be problem ?
Newopint95
Re: Works wrong I guess
Post by Newopint95 » Fri Mar 31, 2017 7:44 am
you need to reverse the direction of your X and Y motors.
indy
Post by indy » Fri Mar 31, 2017 8:19 pm
Newopint95 wrote:you need to reverse the direction of your X and Y motors.
Hmm thanks did not knew you can do that. Going to check settings where can I do that :)
indy
Post by indy » Fri Mar 31, 2017 8:46 pm
Can not find anything in settings.
As I read about similar problems there were some suggestions to change wires for motors, but thats not possible in my case. It does not go in if around.
Some said it should be changed in firmware but I'm not sure where and how.
Any suggestions ?
indy
Post by indy » Sun Apr 02, 2017 11:45 pm
Found that it should be done in firmware, so I found that and updated my motor directions. Now this works fine.
Users browsing this forum: No registered users and 6 guests
