Bltouch in diagosis mode - BRAND NEW
draconisdraco
Post by draconisdraco » Thu Feb 23, 2017 12:36 am
Not much to say really, just un packaged this, connected it to my Rumba ( properly) and all i'm getting is the flashing diag light.
pin moves freely.
std servo on same pins from rumba actuates fine.
bang
Re: Bltouch in diagosis mode - BRAND NEW
Post by bang » Thu Feb 23, 2017 12:31 pm
Maybe you can refer to this post to have a try:
viewtopic.php?f=27&t=18371
draconisdraco
Post by draconisdraco » Fri Feb 24, 2017 2:59 am
I've already done full diagnostics - the pin will not drop / lift on it's own.
bang
Post by bang » Fri Feb 24, 2017 2:25 pm
If that is the case,i guess maybe there is something wrong with you firmware and wiring of 3Dtouch.
Did it do self-test when you power it on?
draconisdraco
Post by draconisdraco » Sat Feb 25, 2017 1:38 am
wiring is fine, and as per the Bltouch guide.
Firmware is set exactly as per the Marlin setup guide, and is confirmed by use of a std servo.
Diagnosis is flashing the second it is powered up - i'm told the pin will lift / drop at power on - this does not happen.
bang
Post by bang » Tue Mar 14, 2017 4:59 pm
Did you fix it?
Could you post a video?
draconisdraco
Post by draconisdraco » Tue Mar 14, 2017 9:15 pm
hi, no - i had it refunded.
After this I metered the coil - it was open and had no resistance, so was not energising.
I have a genuine BLTouch now and it is working flawlessly.
Users browsing this forum: No registered users and 13 guests
