Repetier Feedrate setting for G2S Pro
ratcliffe_mike
Post by ratcliffe_mike » Tue Feb 14, 2017 7:28 pm
I have noticed that I can usually safely move the "feedrate" slider in Repetier manual control to 300% without losing print quality.
This is clearly because something in the firmware is not set properly... it looks to me like the current settings are set for a non-delta printer.
I did come across these settings online but wondered what settings we should be using:
Code: Select all
#define BAUDRATE 250000
#define DELTA_SEGMENTS_PER_SECOND 80
#define DEFAULT_AXIS_STEPS_PER_UNIT   {200, 200, 200, 1330}  // default steps per unit for Kossel (GT2, 20 tooth)
#define DEFAULT_MAX_FEEDRATE                  {8000, 8000, 8000, 6000}    // (mm/sec)
#define DEFAULT_MAX_ACCELERATION        {15000,15000,15000,5000}    // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for skeinforge 40+, for older versions raise them a lot.
#define DEFAULT_ACCELERATION                       3000    // X, Y, Z and E max acceleration in mm/s^2 for printing moves
#define DEFAULT_RETRACT_ACCELERATION  3000   // X, Y, Z and E max acceleration in mm/s^2 for retracts
#define DEFAULT_XYJERK               4.0    // (mm/sec)
#define DEFAULT_ZJERK                 4.0    // (mm/sec)
#define DEFAULT_EJERK                 4.0    // (mm/sec)
Can you let me know which settings have worked best for you?
