Extruder motor doen't works correctly
veromero
Post by veromero » Wed Nov 09, 2016 4:32 am
Hi! Im Vero from Argentina!
The extruder of my Geeetech I3 ProB is not working correctly. When I set to extrude 100mm/s It extrude only 10mm/s (but this shows that the motor works), but then when I send it to print the motor of the extruder doesn't move even a little.
I have another extruder so I changed it in order to identificate the problem, but it happens the same thing. So the problem is on the board. Then I changed the controller chip and mesured the pololu but these things are OK..
Someone have any idea what could be the problem? and any solution? Can I do some changes on the frimware and exchange Extruder 1 with extruder 2 pin or something like that?
I really appreciate your help :D
phildarito
Re: Extruder motor doen't works correctly
Post by phildarito » Wed Nov 09, 2016 2:25 pm
Philippe from France
I bought a GEEETech acrylic i3 pro B and I have exactly the same problem.
I tried with the Z axis motor, with the z axis cable, same problem.
Check the pololu, check the power unit => same problem.
I tried every firmware for the GT2560 in this forum, same problem.
When I change the step/mm for the extruder, same problem.
If I want extrude 100mm (repetier or with the LCD) I only have 14mm :evil:
Dead board or dead firmware ???
Post by William » Wed Nov 09, 2016 3:10 pm
Hi,Philippe
1.Did you check the subdivision?
2.Have you tried swapping the driver A4988 with other motor's?
3.Theoretically,you can modify the step/mm in "Control-Motion" and "Control->Store Memory",then the modifying will come into effect next time.
phildarito
Post by phildarito » Wed Nov 09, 2016 3:58 pm
subdivision checked
driver A4988 swapped
step in marlin
step in repetier
next try ?
14mm for 100mm asked :(
same try with the new firmware received by mail and same result
veromero
Post by veromero » Thu Nov 10, 2016 11:03 pm
Thank you William.. I did all things you say but its still happend the same thing, When I setting on the Repetier to extrude 100mm/min It extrude some 10mm/min and when I send it to print the motor just doesn't move. I change at frimware E0 with E1 and the change it works, but the problem persist!! Im really lost and sourprised ... I change the motor with other motor and its happend the same thing.
Philip the same thing happens to you? If you can solve it please let me know how! I will do the same thing... Im talking with the technical assistance of Geeetech but They still could not solve it...
phildarito
Post by phildarito » Fri Nov 11, 2016 12:04 am
Always the same problem, I think the extruder part of my board is dead.
I swapped the motor, the wires, everything and all of this work fine in the X for exemple, the only answer is dead board.
:evil: :evil: :evil:
veromero
Post by veromero » Fri Nov 11, 2016 8:02 am
Yes.. I think the same... :( .. I swapped the pin of E0 and E1 in refer to this:
http://www.geeetech.com/forum/viewtopic ... 20&t=18020
Thats a really good information that technical suport of Geeetech gave me, but it doesnt work on my case..
phildarito
Post by phildarito » Fri Nov 11, 2016 8:07 am
thank you, I will try soon.
phildarito
Post by phildarito » Fri Nov 11, 2016 2:09 pm
I just tried to swap E0 and E1 and it does'nt work with me too :(
veromero
Post by veromero » Sat Nov 12, 2016 1:11 am
We will have to buy another board :? . :cry: hahah
