Me Creator 2
AcoVanConis
Re: Me Creator 2
Post by AcoVanConis » Sun Apr 09, 2017 12:56 am
Hi John
where is this menu item, in Repetier host I cannot find him
have the same issue, the print is not centered, a litte bit too left
tnx
You have to use the Display and Knob from the Printer.
8ung
Re: Me Creator 2
Post by 8ung » Sun Apr 09, 2017 2:10 am
Thanks works perfect
did a leveiling test http://www.thingiverse.com/thing:34558
and its exact in the middle now
8ung
Re: Me Creator 2
Post by 8ung » Wed Apr 12, 2017 3:31 am
BTW I have to do the reset procedure every startup, is there a way to store it permanent?
tnx
Re: Me Creator 2
Post by William » Thu Apr 13, 2017 11:19 am
Hi,8ung
you can find it in LCD main menu:Control>Store memory.Just the attachment shows.
ejo
Re: Me Creator 2
Post by ejo » Mon May 01, 2017 8:39 pm
My Z gets stuck on ~150mm for no clear reason. Max height should be 160mm, but when it hits that certain point, it won't move up or down anymore. If I tell bed to go up and same time help the lead screw by turning it gently, it starts to move again.
I haven't actually printed anything that tall, I did just test it to make sure what actual height limit is.
8ung
Re: Me Creator 2
Post by 8ung » Thu May 04, 2017 3:27 pm
William wrote:Hi,8ung
tnx William it worked
kr
ejo
Re: Me Creator 2
Post by ejo » Sat May 06, 2017 1:38 am
Two stepper drivers were adjusted to 0.87v and two to 1.13v. I guess motors are the same model, so I did adjust them all to ~1.1v. This didn't help the Z problem. The drivers are not labeled, so I'm not sure which is for which motor.
It is hard to measure, but I think leadscrew is tilted less than millimeter to left. This makes it too tight bed to go all the way down I cannot see a way to tilt it back, construction is too solid.
I did try to loosen various screws and loosening the part that connects bed to lead screw did help a little bit. Now it gets stuck ~158mm and I think I can safely print up to 155mm which is close enough. I did set Cura to 150mm height and only increase it if absolutely necessary.
But I still think this should have been noticed in quality check. You did print a square with this very printer, but didn't bother to check Z height?
Users browsing this forum: No registered users and 15 guests
