prusa I3 X - common issues - diagnostics and calibration
Fer8973
Re: prusa I3 X - common issues - diagnostics and calibration
Post by Fer8973 » Thu Mar 10, 2016 1:26 pm
I already change the direction of X axis, please forget about my other messages. Please delete my posts. My only problem now is the LCS. I'll try to solve it. Thanks for your help.
Fer8973
Post by Fer8973 » Thu Mar 10, 2016 1:45 pm
Mark wrote:the motor direction is reversed, check out this link:
http://www.geeetech.com/forum/viewtopic ... 17&t=17037
Thanks for the help!!!
Post by Mark » Fri Mar 11, 2016 11:24 pm
"1) the LCD is green, it does not display anything; I switched tha cables and there is not any change."
maybe you need to adjust the trimpot on the back of the LCD as this link shows:
http://www.geeetech.com/forum/viewtopic ... 23&t=17040
"2) I download Arduino 1.0.1, selected Mega2560, COM4 and tried to verify the firmware but I got this error message: "
never run into this error before, have you downloaded the correct firmware and how about using another arduino? like 1.5.2
infomats
Post by infomats » Sat May 14, 2016 12:21 am
I have just bought and assembled the printer, but it is not printing properly, it prints but filament is not coming out properly and it becomes a mess , it is just melting the filament and just waisting it, pla help to make it print as i have cleaned the nozzel as well but no luck.
Admin
Post by Admin » Sat May 14, 2016 11:36 am
did you check the extruder? is the extruder motor working well?
infomats
Post by infomats » Sat May 14, 2016 6:32 pm
Yes motor is working but filament seems slowly coming out and making a mess, so rather than printing it is just making mess, it seems that motor is not feeding enough filament.
Admin
Post by Admin » Mon May 16, 2016 11:50 am
infomats wrote:Yes motor is working but filament seems slowly coming out and making a mess, so rather than printing it is just making mess, it seems that motor is not feeding enough filament.
any photos to show the mess and the distance between the nozzle and the heatbed after homing?
infomats
Post by infomats » Mon May 16, 2016 9:00 pm
The main problem is filament is not sticking with the bed, so please let me know what adhesive i should use or any tape i need to use ao the filament sticks with the bed and starts printing.
Orianpax
Post by Orianpax » Fri Jun 10, 2016 7:54 am
When the unit is powered on the heat bed will climb in temperature and will not stop,I switch wires then the nozzle when not stop heating up !!
I can figure it out.
Orianpax
Post by Orianpax » Fri Jun 10, 2016 7:58 am
I have an issue when the unit is powered on the heat bed will climb in temperature and will not stop, and if I switch wires then the nozzle when not stop heating up what is wrong???
Users browsing this forum: No registered users and 1 guest
