Lcd problem when connected to ramps
mava70
Post by mava70 » Tue Nov 24, 2015 4:11 pm
Hello I have had a gt2560 with 2004 lcd. Gt2560 is brocken so I swapped with a standard ramps/2560. Ai have to buy a standard lcd adapter on ebay for connecting 2004 to ramps. When I connect the lcd ribbon
Printer stop working and on pc I see a mintemp error reached. Lcd doesn't work but is correctly connected.
If I disconnect the lcd printer works normally.
Any idea?
Marco
Re: Lcd problem when connected to ramps
Post by Mark » Tue Nov 24, 2015 5:10 pm
which firmware are you using? you need to use the one for ramps board.
mava70
Post by mava70 » Tue Nov 24, 2015 5:18 pm
Yes the firmware is correct your firmware for rakps board prusa b and it works very well when lcd disconnected.
Lcd is correctly configured in config.h same as gt2560 firmware
mava70
Post by mava70 » Wed Nov 25, 2015 5:24 am
solved smart connector connectors are mounted reversed swapped cable now is ok
