Process of upgrading to dual extruder and getting a better hotend
Mikhail
Post by Mikhail » Tue Jun 27, 2017 3:40 pm
Recently I have been trying out more complicated prints that require support material, high detail, and/or high amounts of precision and I would like a second extruder for support material and for quicker infill on precise prints that don't require complex supports. I currently have a prusa I3 pro B with a single extruder and I don't completely understand the process of upgrading and would like some help with the steps on how to do so. Thanks.
I'm also curious about trying out a more precise hot end with a .2 mm diameter, but I don't where I would buy something like that.
Re: Process of upgrading to dual extruder and getting a better hotend
Post by William » Tue Jun 27, 2017 5:20 pm
You can update the latest firmware to achieve more functionality,and here is the download link:
AS for the hot end with a 0.2 mm diameter,you can consult our seller.
Mikhail
Post by Mikhail » Wed Jun 28, 2017 7:30 am
thanks for the reply, but I was wondering about what parts I would need to upgrade.
Newopint95
Post by Newopint95 » Wed Jun 28, 2017 8:01 am
You don't have to upgrade any parts on the Pro B. You will need another hot end and extruder, the plate that came with my Pro B is the same as the Pro C.
You should be able to just add the new parts and flash the firmware and be on your way.
Post by William » Wed Jun 28, 2017 9:43 am
Sorry, I misunderstood your meaning yesterday, As Newopint95 says, you need to add new parts and flash the firmware, and here are some items can help you :
1. A 20A power supply:
http://www.geeetech.com/s25012-12v-20a- ... p-966.html
2. A MK8 dual extruder:
http://www.geeetech.com/mk8-dual-extruder-p-921.html
3.One more A4988 Stepper motor driver:
http://www.geeetech.com/stepper-driver- ... -1007.html
4. A dual extruder holder:
http://www.geeetech.com/mk8-dual-extrud ... p-950.html
If you need them, please contact our sales(sales@geeetech.com).
As to the firmware, please refer to that of pro C model:
http://www.geeetech.com/forum/download/file.php?id=1555
Mikhail
Post by Mikhail » Sun Oct 01, 2017 9:53 am
Thanks for the help. I ended up getting side-tracked over the summer so I haven't gotten around to doing this until now.
Looking at both parts lists, the major expenses will be in both the control board (GT2560+5 A4988) and the dual extruder (MK8 dual extruder). What I currently have in place of those parts are an GT2560+4 A4988 board and a single MK8 extruder. So i'm wondering if its possible to:
1.Buy an additional MK8 extruder and fabricate a housing for both my old one and the new one giving me the same thing as the dual extruder
2.add an additional port to the control board.
Post by William » Thu Oct 05, 2017 11:55 am
1. You can do it by yourself.
2. The board has two extruder port. Just use it.
