G2/2S diagonal rod sliding on the bearing holder?!
Posted: Wed Feb 17, 2016 3:04 pm
by Mark
Sometimes due to the poor quality of the rod-end bearing holder on the Delta Rostock G2/2S, the diagonal rod can not stay put on the holder and sliding back and forth on it, you can try to print a lock ring and secure it as follows:
- ring.jpg (121.76 KiB) Viewed 27963 times
- ring1.jpg (222.49 KiB) Viewed 27963 times
After doing this the positioning will be much more accurate!
Download the stl file here:
Re: G2/2S diagonal rod sliding on the bearing holder?!
Posted: Sun Mar 06, 2016 4:09 am
by spikey1973
had a similar thought.. thank you for sharing this design.. as soon as i get it up and running i will add those printed rings.
Kind greatings
Matt
Posted: Tue Jun 07, 2016 4:58 am
by scunucchiuz
sorry i have a same problem.
you have solved the problem whit washer?
who is possible to buy the aluminum bushing? how much?
Posted: Fri Feb 24, 2017 9:59 pm
by cordon
Hello mark,
I want to make some washers before assembling my Delta Rostock Mini, but the 3D printing shop ask me some dimensions: the height, the outer diameter, etc..
Can you please give some dimensions of the washer?
Thank you.
