Hi,@KiloVolT
Could you please attach a picture of the mentioned part?
Maybe i can help you get it.
For people who wants STL files of parts
Re: For people who wants STL files of parts
![Smile :)](./images/smilies/icon_e_smile.gif)
Does the PI3B-B03 carriage fit for the "Geeetech i3 Pro C".
I want to change my Dual direct drive extruder to Single bowden extruder with Autobed Level....
Are there some .stl files available for the METAL parts of the newer Geeetech Prusa i3 Pro B?
Would be really handy for designing things in CAD.
Thank you!
Thank you!
There are no STL files for new Pro B.
Bonjour,
Voici quelques pièces pour l'imprimante 3D Delta Geeetech Rostock 301 :
https://www.thingiverse.com/thing:2464177
Voir aussi :
http://forums.reprap.org/read.php?178,781375,781375
L'ami René
Voir aussi :
L'ami René
One for all and all for one !
I have a Pro W (which is, of course, cut from plywood). If I want to modify/upgrade/add bits, does it have the same fittings as the Pro B...? If not, what should I use instead?
Hello.
I have a Geeetech I3 Pro W (wood frame) and I need stl files for Y belt holder. At least the only piece which is from plywood.
Is there any chance to find stl files for this printer?
Thank you!
Thank you!
I will check ,if I have this part stl files. I will send it to you.gyany_eugen wrote: ↑Sun Mar 11, 2018 4:52 pmHello.
Thank you!
hi can anyone yell me if there is a stl available for the i3 pro b acyrilic z motor frame part, i broke one during assembly, really would appreciate some help to find this part to print.
best regards
best regards
Hello.
Enter the part number & show photos of the required item. I will see what can be done.
![Wink ;)](./images/smilies/icon_e_wink.gif)
![Mr. Green :mrgreen:](./images/smilies/icon_mrgreen.gif)
