Z motor G code
sjk
Z motor G code
Post by sjk » Tue Jul 07, 2020 5:35 pm
I'm trying to find out why my i3 printer has started to misbehave following a problem where Repetier host froze leaving the nozzle hot and embedded in a print. At the start of a new print the Z motors screech and don't necessarily move to the same height. The code always starts:
11 M201 X9000 Y9000 Z500 E10000 ; sets maximum accelerations, mm/sec^2
12 M203 X500 Y500 Z12 E120 ; sets maximum feedrates, mm/sec
13 M204 P1500 R1500 T1500 ; sets acceleration (P, T) and retract acceleration (R), mm/sec^2
14 M205 X10.00 Y10.00 Z0.20 E2.50 ; sets the jerk limits, mm/sec
15 M205 S0 T0 ; sets the minimum extruding and travel feed rate, mm/sec
16 M107
17
18 G28 ; home all axes
19 G1 Z5 F5000 ; lift nozzle
(I've removed the temperature settings so I can test easily)
The problem is at line 19. The lift is very fast (5000) even though line 12 says the max is 12. Is one of them in mm/s and one in mm/min?
If I set the line 19 value to a small value, everything works fine but of course I can only do that by manually modifying every gcode I produce. And in any case, there wasn't a problem till just a few days ago.
Any ideas?
I have checked the Z motor voltage and it's 1.17V
arronwan
Re: Z motor G code
Post by arronwan » Wed Sep 30, 2020 9:38 pm
thanks this helped a lot
dropletwant
Re: Z motor G code
Post by dropletwant » Sun Oct 04, 2020 8:36 pm
I am very much that on this site payforessay.net I can always order an essay and I know that they will do it for me in the shortest possible time and not expensive. And that's why I always order essays on the site.
Users browsing this forum: No registered users and 42 guests
