Page 1 of 2
Easyprint 1.2.6 new bug discovered
Posted: Tue Jul 23, 2019 2:05 am
by Kibo
Hallo there,
I am currently experimenting with different support settings. There I noticed a bug (I think):
Eaysyprint 1.2.6 --> Slicing Settings --> Parameters (---> enable support) --> Z distance:
This parameter seems to define the distance between the actual print and the support. The default setting is 0,1 mm. However, entered values <1mm do not have any effect. Only parameters >1mm (which are definitely not practical) have an actual effect.
Can anyone confirm this issue?
Kind regards
René
Re: Easyprint 1.2.6 new bug discovered
Posted: Tue Jul 23, 2019 9:15 am
Thanks for your feedback.
Posted: Tue Jul 23, 2019 9:43 am
by Tomyuan
William wrote: ↑Tue Jul 23, 2019 9:15 am
Hi willliam, why not try it at first?
You can check the software fast and he just wants an answer.
Posted: Tue Jul 23, 2019 10:01 am
, I have tried it, it can be set.
- easyprint.png (43.44 KiB) Viewed 18042 times
Posted: Tue Jul 23, 2019 2:34 pm
by Tomyuan
Hi, William.
You can try to set it to different values.
Then import the stl file and click slice.
Compare them then you will mean what I am talking about.
Posted: Tue Jul 23, 2019 4:14 pm
OH, you can observe the distance transform I set
0.2mm
- 0.2.png (145.72 KiB) Viewed 17990 times
2mm
- 2.png (131.5 KiB) Viewed 17990 times
However, we set up support to ensure that the suspended parts do not fall. So can't be set too big.
Posted: Wed Jul 24, 2019 4:35 am
by Kibo
Yes, you can set the value but it does not have any effect on the model. I also enabled support interface. I don´t know if this has any influence on it. I took a few screenshots.
Here I set the Z-distance to 1 mm. The gap is clearly visible:
- Z distance 1 mm.JPG (157.43 KiB) Viewed 17927 times
Here I set the Z-distance to 0,9 mm. There should not be a large difference visible but for every value <1 mm the gap seems to be non existent.
- Z distance 0.9 mm.JPG (123.89 KiB) Viewed 17927 times
And the slicer settings:
- Slicer Settings.JPG (86.12 KiB) Viewed 17927 times
Posted: Wed Jul 24, 2019 4:37 am
by Kibo
William wrote: ↑Tue Jul 23, 2019 4:14 pm
Yes, I can confirm that there is a difference between values <1 mm and >1 mm but there is no difference between values <1 mm. So let´s say 0,1 mm isn´t any different to 0,9 mm.
Posted: Wed Jul 24, 2019 9:24 am
Hi, but in fact, the support is to protect your dangling parts, so you don't need to adjust the values very much.
Posted: Thu Jul 25, 2019 3:38 am
by Kibo
I just read a good tutorial on how to improve the print quality when using support. There they experimented with different Z distances. I would very much appreciate it, if this feature was added in a future version of easyprint.
