Print starts without heating the nozzle
Fred1
Post by Fred1 » Sun Jan 21, 2018 9:13 am
Hi guys,
I've got my I3 Pro B in December, so I'm still a dump newbie.
I ordered a 3D touch and got it run ( after a lot of reading and try with the Firm Ware )
Using Marlin-PI3_Pro_B_3DTouch (A+) FW. Board 2560 REV A+
First print I realized that my nozzle is not low enough and the pin of 3D touch was hitting the print. I departed before
Ok after resetting all, had a lot of issues to set the Z offset again, but that's done now.
( I had to flash first an older Fw then, the right one to get some changes ---very strange to me )
Any way now is my problem that the print doesn't start because the heat setting are both on zero ( visible on the LCD ) it comes heating up but .../0
Here is my start code:
;FLAVOR:Marlin
;TIME:4511
;Filament used: 2.37263m
;Layer height: 0.1
;Generated with Cura_SteamEngine 3.1.0
M190 S50
M104 S195
M109 S195
M82 ; absolute extrusion mode
G21 ;metric values
G90 ;absolute positioning
M82 ;set extruder to absolute mode
{IF_BED}M190 S{BED}
; Activate all used extruder
{IF_EXT0}M104 T0 S{TEMP0}
G92 E0 ; Reset extruder position
; Wait for all used extruders to reach temperature
{IF_EXT0}M109 T0 S{TEMP0}
M107 ;start with the fan off
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
G29 , AutoLevel 3DTouch (BLTouch)
G1 Z15.0 F9000 ;move the platform down 15mm
G92 E0 ;zero the extruded length
G1 F200 E3 ;extrude 3mm of feed stock
G92 E0 ;zero the extruded length again
G1 F9000
M117 Printing...
;LAYER_COUNT:310
;LAYER:0
M107
G0 F3600 X73.906 Y89.919 Z0.3
;TYPE:SKIRT
Maybe the firm ware is wrong as well
Has anybody an idea what's wrong
Thanks in advance Fred
Re: Print starts without heating the nozzle
Post by William » Mon Jan 22, 2018 4:44 pm
You can try to change"M104 S195" to "M104 T0 S195"
"M109 S195"to"M109 T0 S195"
Connor
Post by Connor » Thu Jan 25, 2018 5:59 pm
Got it! Thanks.
Fred1
Post by Fred1 » Fri Jan 26, 2018 10:12 am
Hi William, thanks for your answer, I fixed it my self.
I use now i simple start code:
;FLAVOR:Marlin
;TIME:7707
;Filament used: 3.54472m
;Layer height: 0.1
M190 S60
M104 S195
M109 S195
;FLAVOR:Marlin
M190 S50
M104 S195
M109 S195
G21 ;metric values
G1 F9000
M117 Printing...
;LAYER_COUNT:590
;LAYER:0
M107
that's working now, only my end code seems to be still wrong or something missing.
The issue is after finishing a print the extruder is not moving down in z direction correctly it is only in 0 position x and y.
when I start another print from this position the moving in z stops before it reach the bed so it will print in air.
So I have to do home position via LCD before I can start a print.
Here's my end code:
M107
M104 S0 ;extruder heater off
M140 S0 ;heated bed heater off (if you have it)
G91 ;relative positioning
G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure
G1 Z+0.5 E-5 X-20 Y-20 F9000 ;move Z up a bit and retract filament even more
G28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way
M84 ;steppers off
M104 S0
;End of Gcode
Use G1 Z+15; move z aches to 15mm, after G28 would be right?
Ok, I can start always a manual home but maybe you know a way to change the end code.
Now I wanna ask you about my main problem, is my Auto Touch already broken?
After about 5 minutes print the Touch is blinking and short after that the pin is coming down and hit the print.
the nozzle offset is set to -1.00mm and the brim and first layer is set to .3 mm the layer looks ok.
Hope you understand everything English is not my first language.
Thanks Fred
