How do I configure my Geeetech i3 Pro C with slic3r to print two colors?
Slic3r two-color printing with Geeetech i3 pro C
Re: Slic3r two-color printing with Geeetech i3 pro C
You can refer to this section in your ProC User Manual:
hi,
I tried as instructed but the two-color printing will not start.
That configuration should use on repieter to make it work?
where I find this file for geeetech i3 pro c?
I3B_2E_config_bundle.ini
Check if there is relevant code in G-gode file for the heating of extruder1 and extruder2 after slicing the model.
Here
; generated by Slic3r 1.2.9 on 2017-02-09 at 10:56:30
; external perimeters extrusion width = 0.30mm
; perimeters extrusion width = 0.30mm
; infill extrusion width = 0.40mm
; solid infill extrusion width = 0.40mm
; top infill extrusion width = 0.40mm
M107
M190 S80; wait for bad temperature to be reached
M104 S200; set extruder temperature
G28 ; home all axes
G1 Z5 F5000 ; lift nozzle
G21 ; set units to millimeters
G90 ; use absolute coordinates
M82 ; use absolute distances for extrusion
G92 E0
M107
G28 ; home all axes
G92 E0
Why the press so?
It moves everything right and does not go downtown
Do not look at the quality I have to fine tune the dish.
- IMG_4097.JPG (183.37 KiB) Viewed 14075 times
You mean what?The white part?
What does the model look like?
I guess you didn't configure the two settings in your slicer settings?
