Slic3r setting for I3 Pro B
BlastF
Post by BlastF » Tue Nov 29, 2016 6:36 pm
Hi guys, i'm testing the new version of slic3r prusa version on my prusa i3 Pro B and i'm having a hard time find the right settings, can you help me?
many thanks :D
Re: Slic3r setting for I3 Pro B
Post by William » Tue Dec 06, 2016 2:40 pm
Try the attached config(for nozzle size 0.3 and 0.4mm):
I3 B-PLA-0.4-1.75.zip
(1.35 KiB) Downloaded 5305 times
I3 B-PLA-0.3-1.75.zip
(2.85 KiB) Downloaded 4284 times
TurboJoke
Post by TurboJoke » Sat Nov 10, 2018 10:28 pm
Hi!
Do you have configurations for ABS and SBS?
Post by William » Tue Nov 13, 2018 9:27 am
Hi!
For ABS:You need to set the first layer to 0.2mm.
Then you need to set the nozzle temp to 230~260C.
For heat bed:90~100C
But I didn't try to use SBS ,I can't give you more suggestion for it.
