I have built and calibrated manually the G2s Pro, printed a couple of products, but so far I have been unable to run the auto bed levelling.
I have the Geeetech version of Marlin and running through Repetier Host. I have the probe limit set on Z min to the to the GT2560 control board.
Do I need to make some changes in the Marlin Firmware? and what G codes do I need to run in order to use the auto bed levelling.
Setting up auto bed levelling G2s Pro
Re: Setting up auto bed levelling G2s Pro
Did you get the quicker starter manual? it will tell you how to do this, you can download it here:
http://www.geeetech.com/delta-rostock-m ... p-936.html
Thanks Mark, no I didn't receive that link or manual, will go through that. cheers
