Hi all,
I have a Prusa I3 Pro C and I am trying to use it with Cura.
I had to insert two different configurations:
1) single extruder config: it works great with one extruder
2) double extruder config: it works great BUT only after the "dual extruder merge" operation
in this configuration is not possible to print simple object with first or second extruder only
I cannot print an object using only the second extruder.
Any suggestions?
Max
Prusa i3 pro C and Cura -> problems
Re: Prusa i3 pro C and Cura -> problems
what is the "dual extruder merge" operation ? I think if you want to print with single extruder , just select the extruder you want to use is enough, and then slice it, isn't it?
Thanks a lot Mark.
The software you are using is Repetier Host, not Cura.
Actually I cannot use RH because the Mac version is very old and doesn't support dual extruder printers.
Max
Max
