My slicer settings
zhangxueyou
My slicer settings
Post by zhangxueyou » Sat May 09, 2015 10:37 am
I use Geeetech Prusa i3B, with 1.75mm filament and 0.3mm diameter. Slicer software is Slic3r. Attachment is my slicer settings, I got good print with these settings, you can try.
Actually, anyone who uses different kinds of printer, or the same printer with different filament diameter or nozzle diameter, can also refer to this setting. But you have to change some parameters in slic3r, including "filament diameter", "nozzle diameter", "first layer height"(it is as same as nozzle diameter), "other layers height"(I suggest lower than first layer for 0.05-0.1mm).
slicer settings(1.75mm-0.3mm).zip
(388.83 KiB) Downloaded 1979 times
zhangxueyou
Re: My slicer settings
Post by zhangxueyou » Tue May 12, 2015 5:24 pm
You can also load the configuration file directly.
import slicer setting 1.png (46.16 KiB) Viewed 39091 times
Open slic3r in Repetier Host:
import slicer setting 2.png (52.58 KiB) Viewed 39091 times
import slicer setting 3.png (87.36 KiB) Viewed 39091 times
slicer config.zip
(1.27 KiB) Downloaded 1659 times
johnz
Post by johnz » Wed Jun 03, 2015 2:23 am
What speed on the feed rate and flow rate??
zhangxueyou
Post by zhangxueyou » Wed Jun 03, 2015 10:04 am
johnz wrote:What speed on the feed rate and flow rate??
1 or 1.1 maybe.
johnz
Post by johnz » Wed Jun 03, 2015 10:23 am
Ok how about on the Repetier v1.0.6
zhangxueyou
Post by zhangxueyou » Wed Jun 03, 2015 10:29 am
johnz wrote:Ok how about on the Repetier v1.0.6
I use Repetier1.0.6 exactly. And I use the slicer settings as the attachment above, and it prints fine.
thhale
Post by thhale » Sat Aug 27, 2016 1:16 pm
Thanks for sharing.
gpau
Post by gpau » Mon Dec 26, 2016 3:17 am
where I find the slicer setting for mac Ios?
Thank you
Cup
Post by Cup » Wed Dec 28, 2016 1:50 pm
@gpau
So the Mac version doesn't recoganize the .ini format file?
gpau
Post by gpau » Fri Feb 10, 2017 6:58 am
@cup
ok,
I can get it for windows
thanks
