Firmare does not finish upload
cois99
Post by cois99 » Wed Apr 01, 2020 11:07 pm
Hi i have a i3 pro w 3d printer with a Gt2560 bord , I had the problem of just black bars on my lcd and sucsessfully re-uploaded the firmaware , but it has happend again , and now every time I try to re-upload the firmare i get this error messages ( avardude :stk500v2_ReciveMessage():timeout) and after a while (
avrdude: stk500v2_ReciveMessage(): timeout
avrdude: stk500v2_ReciveMessage(): timeout communicating with programmer
avrdude: stk500v2_command(): failed miserably to execute command 0x11
avrdude: stk500v2_disable (): failed to leave programming mode )
at this point i dissconnected to bord .
I am useing Arduino1.0.1
Things i have tried but dont work ,
-re-instaling the usb driver
-Useing Arduino 1.0
-Useing Arduino 1.5.1
-Useing Arduino 1.8.1.1
-Useing a new usb cable
Useing i 3 pro b firmware
so HELP pls..
Re: Firmare does not finish upload
Post by William » Thu Apr 02, 2020 9:28 am
Hi, You need to install the corresponding serial port,
You can refer to: https://www.geeetech.com/forum/viewtopi ... RlcFtWdCG4
You need to close other slicing software when uploading firmware.
Avoid occupying ports,
You can restart the computer to see the situation.
You can download the firmware on the official website: https://www.geeetech.com/download.html?download_id=36
Then upload it using the firmware toolkit,
You can refer to: viewtopic.php?f=20&t=69684
