Hi All,
I'm trying to add a BL Touch to my Aluminium Pro A the one with the separate control box and leadscrews.
I have downloaded the firmware for my printer but have a problem with trying to identify the correct lines to alter in the pins.h
section as instructed in the Geeetech BL touch manual.Any help would be great or a copy of the firmware already setup for the
BL touch would be even better.
Cheers
Barry
Bl Touch firmware
Re: Bl Touch firmware
I am afraid that all aluminum models are not suitable for installing 3D Touch.
Hi William,
It appears a BL touch can be used I found this on the forum http://www.geeetech.com/forum/viewtopic ... 499#p91203
So I will try the method he describes. The only thing that I would have preferred is a method of connecting to the terminals on the sub board on the printer and not having to go to the main board in the control box.
Cheers
Barry
Cheers
Barry
,OK,Worth a try.
