How to install the firmware for GT2560
Re: How to install the firmware for GT2560
Post by William » Wed Feb 13, 2019 11:30 am
Anonymous1234567890 wrote:
Tue Feb 05, 2019 9:42 am
I tried uploading to my i3 Pro X but I get this error:
Code: Select all
Arduino: 1.8.8 (Windows Store 1.8.19.0) (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
                 from sketch\planner.cpp:54:
 #define X_MAX_PIN          -1
 #define X_MAX_PIN 24
 #define Y_MAX_PIN          -1
 #define Y_MAX_PIN 28
                 from sketch\SdBaseFile.cpp:21:
sketch\pins.h:2958:0: warning: "Z_MAX_PIN" redefined
 #define Z_MAX_PIN          -1
sketch\pins.h:1375:0: note: this is the location of the previous definition
 #define Z_MAX_PIN 32
                 from sketch\stepper.cpp:24:
                 from sketch\Sd2Card.cpp:20:
                 from sketch\temperature.h:24,
                 from sketch\ultralcd.cpp:1:
                 from sketch\BlinkM.cpp:5:
In file included from sketch\SdBaseFile.cpp:24:0:
SdBaseFile.h:38:8: error: using typedef-name 'fpos_t' after 'struct'
 struct fpos_t {
c:\program files\windowsapps\arduinollc.arduinoide_1.8.19.0_x86__mdqgnx93n4wtt\hardware\tools\avr\avr\include\stdio.h:950:33: note: 'fpos_t' has a previous declaration here
sketch\SdBaseFile.cpp: In member function 'void SdBaseFile::getpos(fpos_t*)':
SdBaseFile.cpp:298:8: error: request for member 'position' in '* pos', which is of non-class type 'fpos_t {aka long long int}'
   pos->position = curPosition_;
SdBaseFile.cpp:299:8: error: request for member 'cluster' in '* pos', which is of non-class type 'fpos_t {aka long long int}'
   pos->cluster = curCluster_;
                 from sketch\motion_control.cpp:22:
                 from sketch\SdFile.cpp:20:
sketch\SdBaseFile.cpp: In member function 'void SdBaseFile::setpos(fpos_t*)':
SdBaseFile.cpp:1496:23: error: request for member 'position' in '* pos', which is of non-class type 'fpos_t {aka long long int}'
   curPosition_ = pos->position;
SdBaseFile.cpp:1497:22: error: request for member 'cluster' in '* pos', which is of non-class type 'fpos_t {aka long long int}'
   curCluster_ = pos->cluster;
                 from sketch\cardreader.h:8,
                 from sketch\stepper.cpp:30:
 struct fpos_t {
                 from sketch\ultralcd.cpp:6:
 struct fpos_t {
                 from sketch\SdFile.cpp:23:
 struct fpos_t {
                 from sketch\SdFatUtil.cpp:20:
exit status 1
                 from sketch\cardreader.cpp:1:
                 from sketch\MarlinSerial.cpp:23:
                 from sketch\cardreader.cpp:2:
 struct fpos_t {
                 from sketch\thermistortables.h:4,
                 from sketch\Configuration.h:792,
                 from C:\Users\Owner\Desktop\I3_pro_X\Marlin\Marlin.ino:33:
                 from sketch\vector_3.cpp:20:
                 from sketch\temperature.cpp:32:
                 from sketch\digipot_mcp4451.cpp:1:
sketch\Marlin_main.cpp:2667:36: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
sketch\temperature.cpp:565:50: warning: extra tokens at end of #ifdef directive
     #ifdef THERMAL_RUNAWAY_PROTECTION_BED_PERIOD && THERMAL_RUNAWAY_PROTECTION_BED_PERIOD > 0
                 from sketch\ConfigurationStore.cpp:1:
                 from sketch\Servo.cpp:44:
 struct fpos_t {
I know, it's a long error but I need to know how to fix it. :geek: :geek: :?
It means you try to upload the fw via Arduino 1.6.5 or higher.
Try to upload it via Arduino 1.0.1.
Mad Monkey
Post by Mad Monkey » Wed Apr 03, 2019 2:39 am
I have a brandnew i3 Pro W that i have built
i attempted to print using sd card and it just says none installed, tried via USB and it didnt respond, all signs pointed to updating firmware..
i hooked the pc up to printer, downloaded the Prow firmware from this forum. and ardino 1.01.
verified the sketch and it verifies (baord 2560 com3)
when i click upload it loads 80% of the way and just hangs out.. no error, i left it for over an hr same result.
when i uplugged it i now have a blank screen on my LCD..
please advise what software and firmware files i ACTUALLY need.
Mad Monkey
Post by Mad Monkey » Wed Apr 03, 2019 3:12 am
i have tried several times to add the Prow firmware to my printer, using arduino 1.0.1 and it verifies fine, but when i click upload it gets almost there and doesnt complete no errors
Mad Monkey
Post by Mad Monkey » Wed Apr 03, 2019 5:53 am
Ive let it run now and im getting time out errors..
ive followed everything on this page http://www.geeetech.com/forum/viewtopic ... 20&t=17102
short of resoldering the crystal.. what am I missing?
Mad Monkey
Post by Mad Monkey » Wed Apr 03, 2019 8:12 am
resoldering did nothing. still times out regardless of which usb port i use or cable. etc.
the board is comepletely disconnected and stil fails.
Post by William » Wed Apr 03, 2019 10:08 am
Hi,Mad
I think you should check the hardware at first.
If your printer has an issue of the power,it may cause you can't upload the fw to your printer.
You can use the multimeter check the PSU output is normal (12V).
Or you can try to upload the fw without the PSU cable but get the power from the USB cable.
Mad Monkey
Post by Mad Monkey » Fri Apr 05, 2019 7:27 am
I tried several times uploading firmware with the board completely disconnected just plugged in via USB..
I was able to get the printer operating again but I'd still like to update the fw at some point
alecs13
Post by alecs13 » Wed Apr 24, 2019 5:17 am
hi guys ! Very new and newbie at Arduinos and programing !
So i have tried to upload the Merlin firmware to my GT2560 I get this error; any idea how to fix it ?
dga78
Post by dga78 » Thu May 02, 2019 11:59 pm
Hi guys
Some help please.
Just built a pro x and uploaded firmware (arduino 1.0.1 with Marlin) on my MAC. Firmware loaded and I can connect via USB with Repetier, but the LCD has both lines blocked out. Any ideas?
lvet
Post by lvet » Thu Jun 13, 2019 4:09 am
I have an i3 Pro B bough a couple of weeks ago, I am about to install the 3Dtouch sensor and need to update the firmware.
Is there a way to update the firmware with a more recent version of Arduino 1.0.1?
Trying to run Arduino 1.0.1 on a MacOS Mojave is a pain, as you need to install legacy versions of JVM.
Is there a more recent 3DTouch compatible firmware that I could upload with a more recent version of Arduino?
Please let me know
Cheers
Luca
Locked
