How to install the firmware for GT2560
Locked
Inferno
Re: How to install the firmware for GT2560
Post by Inferno » Thu May 25, 2017 9:57 am
William wrote:Hi,after everytime you change the value of Xsteps and Ysteps setting ,you need to store the memory at Main>Control>Store memory.
My machine does not have the option to store.
Master Chris
Post by Master Chris » Mon May 29, 2017 8:24 pm
Hi Guys
My firmware problems are fixed thanks to everyone for there input
thanks
Chris
claudiofuzzi
Post by claudiofuzzi » Mon Jan 15, 2018 7:46 am
Good evening I have a pro w.
I tried to update the firmware (ProW.zip) but I get this error:
Arduino:1.8.5 (Windows Vista), Scheda:"Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
from sketch\BlinkM.cpp:5:
#define X_MAX_PIN -1
#define X_MAX_PIN 24
#define Y_MAX_PIN -1
#define Y_MAX_PIN 28
sketch\pins.h:2958:0: warning: "Z_MAX_PIN" redefined
#define Z_MAX_PIN -1
sketch\pins.h:1375:0: note: this is the location of the previous definition
#define Z_MAX_PIN 32
from sketch\ConfigurationStore.cpp:1:
from sketch\thermistortables.h:4,
from sketch\Configuration.h:792,
from C:\Users\Daria De Bartolomeo\Desktop\ð-¢¿+-+¦+ð\I3proW\Marlin\Marlin.ino:33:
from sketch\MarlinSerial.cpp:23:
sketch\Marlin_main.cpp:2667:36: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
from sketch\cardreader.h:8,
struct fpos_t {
c:\program files\arduino\hardware\tools\avr\avr\include\stdio.h:950:33: note: 'fpos_t' has a previous declaration here
exit status 1
Questo report potrebbe essere più ricco di informazioni abilitando l'opzione
"Mostra un output dettagliato durante la compilazione"
in "File -> Impostazioni"
How can I do?
Thank you
Post by William » Mon Jan 15, 2018 2:59 pm
struct fpos_t {
exit status 1
How can I do?
Thank you
You should upload it via Arduino 1.0.1
claudiofuzzi
Post by claudiofuzzi » Mon Jan 15, 2018 4:36 pm
Thanks I'll try with arduino 1.0.1
Regards
draconisdraco
Post by draconisdraco » Sat Feb 03, 2018 8:43 pm
new printer...same old problem - outdated SDK support - I'm running latest Arduino SDK ( I use arduino a fair bit).
So i'm getting this error during compile:
exit status 1
Uploading a simple script works perfectly ( for example Blink).
time to update your base firmware, Geeetech - poor show.
Post by William » Mon Feb 05, 2018 4:57 pm
You can try uploading the firmware---Marlin 1.1.8
draconisdraco
Post by draconisdraco » Mon Feb 26, 2018 1:04 am
yet again another vendor using massively out of date SW... no shock there, then.
ArcAiN6
Post by ArcAiN6 » Sun Apr 01, 2018 11:32 pm
I kind of have to agree with everyone else on this one.
There's absolutely NO legitimate reason to be using such an outdated IDE.
Not only does it lead to incompatibilities in newer environments, but in this case, you're costing yourself, and the customers money, by having them download 200+mb of outdated IDE, just to work with your product.
Now, what would REALLY be a good idea, is to update to the latest IDE, and Marlin, with the default arduino bootloader on the atmega2560, that way updating firmware from the user's standpoint is much easier. They don't need to search the entire web to find information that is easy to understand, and works, and they won't need to worry about conflicts that arise when trying to use an EXTREMELY outdated IDE, in a build environment that has the latest IDE already installed.
I would hope that Geeetech takes the time to make this transition from antiquated, obsolete software, to the more stable, and easily extended newer IDE.
Post by William » Mon Apr 02, 2018 7:57 pm
Thanks for your feedback!
Locked
