Page 36 of 39
Re: Firmware for geeetech 3D printers
Posted: Wed Mar 13, 2019 2:58 pm
I've checked your info again.
Here:
The motherboard won't work until you plug the USB cable.
Then I think the board seems can't get the power from the PSU.
You should check the PSU output +motherboard fuse.
Posted: Thu Mar 14, 2019 6:35 pm
by iherbak
Hi all,
I've downloaded the firmware for Gt2560 rev b, but there are no separated config files for 3d touch.
Is it on purpose?
Posted: Sat Mar 16, 2019 12:13 am
by joe88
is there an official newer version for the i3 Pro W coming?
i would need the bilinear autobed leveling.
Regards
Posted: Sat Mar 16, 2019 10:43 am
Regards
The prob use the same hot bed,motherboard and hotend (Refer to the PROW)
It means you can upload the fw of prob.
viewtopic.php?f=20&t=60826 ;)
Posted: Sat Mar 16, 2019 6:19 pm
by screwugr
Hello guys !
im having trouble to find the right firmware for my Geeetech M201 Mixcolor 3D printer with GTM32 PRO VB board .can anyone help please?
Posted: Mon Mar 18, 2019 2:10 am
by _kaktus_
Hello screwugr.
Our printer model has its own subforum, start reading them there is everything explained.
The latest firmware version for M201 is 1.0.03 (GTM32Pro vB).
Posted: Wed Apr 03, 2019 2:50 am
by Mad Monkey
I have a brandnew i3 Pro W that i have built
i attempted to print using sd card and it just says none installed, tried via USB and it didnt respond, all signs pointed to updating firmware..
i hooked the pc up to printer, downloaded the Prow firmware from this forum. and ardino 1.01.
verified the sketch and it verifies (baord 2560 com3)
when i click upload it loads 80% of the way and just hangs out.. no error, i left it for over an hr same result.
when i uplugged it i now have a blank screen on my LCD..
please advise what software and firmware files i ACTUALLY need.
Posted: Mon Apr 08, 2019 6:54 am
by Eclipses
can someone please explain me exactly to what kind of machine does the firmware "PI3A Pro(for the upgraded kit using lead screw).zip" refer to? I bought a PI3A Pro and it has lead screw as default, was there a PI3A Ori without lead screw?
Posted: Mon Apr 08, 2019 12:44 pm
by _kaktus_
Hi.
The difference is due to the use of different types of screws for the Z axis. In the past, ordinary metric M8 screws were used, then trapezoidal threaded hauling screws, e.g. TR8x2.
Getech i3 pro C (Marlin 1.1.8 for all) Arduino IDE Warning (SOLVED)
Posted: Mon Apr 15, 2019 3:16 pm
by calinb
I am interested in upgrading my Ultimaker UMO (purchased in 2012) by installing a new GT2560 A+ board (and a few other new features). If it works well, I plan to purchase a Getech i3 pro C too (so I will have both 1.7 mm and 2.85 mm filament printers :D ). I always run custom Marlin so I thought I'd try building the latest Getech i3 pro C (Marlin 1.1.8 for all) source code first. Here is the source code:
6) Firmware for I3 pro C
Update:
Fixed the endstop error(Default endstop logic status is the"false")
2019/2/27
Marlin 1.1.8 for proC with GT2560VA/A+/2.0
1.Inculde 3dtouch config and no 3dtouch cofing
2.Added the new menu for extruder+hotend
viewtopic.php?f=20&t=17046&p=27625#p27625
Sadly, Arduino 1.8.5 and 1.8.9 both produced warnings after I extracted the files from the .zip archive (and I do not like warnings that can be corrected). See the warnings below.
To eliminate all the redefinition warnings, I un-commented a conditional define in pins_GT2560_REV_A.h.
Change
Code: Select all
//#ifndef BOARD_NAME
   #define BOARD_NAME "GT2560 Rev.A"
//#endif
to
Code: Select all
#ifndef BOARD_NAME
#endif
and all of the following warnings vanish! :idea:
Code: Select all
In file included from sketch/pins_GT2560_REV_A_PLUS.h:29:0,
                 from sketch/pins.h:176,
                 from sketch/MarlinConfig.h:34,
                 from sketch/Marlin.h:36,
                 from sketch/Marlin_main.cpp:249:
sketch/pins_GT2560_REV_A.h:34:0: warning: "BOARD_NAME" redefined
In file included from sketch/pins.h:176:0,
sketch/pins_GT2560_REV_A_PLUS.h:27:0: note: this is the location of the previous definition
 #define BOARD_NAME "GT2560 Rev.A+"
                 from sketch/nozzle.cpp:23:
                 from sketch/SdVolume.cpp:29:
                 from /home/demo/3D_Printer/Marlin/Getech i3 pro C (Marlin 1.1.8 for all)/Marlin/Marlin.ino:31:
                 from sketch/MarlinSerial.cpp:35:
                 from sketch/Max7219_Debug_LEDs.cpp:54:
                 from sketch/G26_Mesh_Validation_Tool.cpp:27:
                 from sketch/dac_mcp4728.h:30,
                 from sketch/dac_mcp4728.cpp:33:
                 from sketch/I2CPositionEncoder.cpp:31:
                 from sketch/Sd2Card.cpp:29:
                 from sketch/digipot_mcp4451.cpp:23:
                 from sketch/hex_print_routines.cpp:22:
                 from sketch/endstops.cpp:27:
                 from sketch/printcounter.cpp:23:
                 from sketch/serial.h:26,
                 from sketch/serial.cpp:23:
                 from sketch/digipot_mcp4018.cpp:23:
                 from sketch/leds.cpp:27:
                 from sketch/planner_bezier.cpp:30:
                 from sketch/least_squares_fit.cpp:35:
                 from sketch/servo.cpp:53:
                 from sketch/M100_Free_Mem_Chk.cpp:51:
                 from sketch/SdBaseFile.cpp:30:
                 from sketch/SdFile.cpp:29:
                 from sketch/SdFatUtil.cpp:29:
                 from sketch/enum.h:26,
                 from sketch/gcode.h:32,
                 from sketch/gcode.cpp:27:
                 from sketch/planner.cpp:61:
                 from sketch/stepper.cpp:47:
                 from sketch/stopwatch.cpp:23:
                 from sketch/ubl_motion.cpp:22:
                 from sketch/stepper_indirection.h:47,
                 from sketch/stepper_indirection.cpp:34:
                 from sketch/neopixel.cpp:27:
                 from sketch/pca9632.cpp:28:
                 from sketch/stepper_dac.cpp:44:
                 from sketch/blinkm.cpp:27:
                 from sketch/cardreader.cpp:23:
                 from sketch/mesh_bed_leveling.h:23,
                 from sketch/mesh_bed_leveling.cpp:23:
                 from sketch/ubl_G29.cpp:23:
                 from sketch/temperature.cpp:27:
                 from sketch/twibus.cpp:23:
                 from sketch/configuration_store.h:26,
                 from sketch/configuration_store.cpp:190:
                 from sketch/utility.cpp:23:
                 from sketch/ultralcd.cpp:23:
                 from sketch/ubl.cpp:23:
                 from sketch/watchdog.cpp:23:
                 from sketch/vector_3.cpp:42:
