How to upload the firmware
zhangxueyou
Re: How to upload the firmware
Post by zhangxueyou » Wed May 20, 2015 9:54 am
Bright Idea wrote:A message saying "example_configurations cannot be added to the sketch" pops up as I drag the whole files into arduino. Except the code files in "example_configurations" folder which are four, I have 57 cpp and header files only under Marlin folder and I'm not sure if all the files are correctly loaded because arduino only displays 48 files maximum.
I think I see where the problem is.
arduino can only read .h file and .cpp file. You should not drag other type of file into arduino.
jaapschaap
Post by jaapschaap » Sat May 23, 2015 8:31 pm
I'm looking for the Sanguino firmware for the GEEEtech i3B Pro Black acrylic 1.75 mm, regular and marlin please so i can use/test both!
Thanks!
thrylos
Post by thrylos » Fri May 29, 2015 2:12 am
I need the firmware that came with my Geeetech i3 pro b with the LCD2004 my board is sanguinololu. tomwillard24@gmail.com
