How to update the hex firmware via cura
Post by William » Tue Dec 10, 2019 10:29 am
Hi,Guys
something about how to update the hex firmware via cura
:lol: 1.you need open cura
If your computer cannot automatically generate ports,
You need to install the driver manually.
you can refer to this: https://www.geeetech.com/forum/viewtopi ... RlcFtWdCG4
2.Download the hex firmware you need on the official website
PS:(I downloaded A20M)
you can download this link: https://www.geeetech.com/
3.choose the settings-printer-manage printer
4.choose printer-update firmware
choose you download the hex firmware
5.done
Vene90
Re: How to update the hex firmware via cura
Post by Vene90 » Sat Jan 25, 2020 12:30 am
This is not working for me. I even try the method hold reset button and click update but after I put hex file in it just fail and than I can not even press to chose an file. Just like no printer connected.
Chub
Post by Chub » Mon Feb 17, 2020 8:12 am
Bernie to upgrading Marlin. So all I have to do is download configuration files and upgrade through Cura? No Arduino stuff? I am on Marlin 1.8. Can I load anyone's A10M config? Is the official Geeetech files 1.19 or 2.0?
Hopefully it is that easy. I have read that some people have issues after update. What can I expect?
Thanks in advance
Chub
Post by Chub » Mon Feb 17, 2020 8:13 am
So to upgrade to Marlin. So all I have to do is download configuration files and upgrade through Cura? No Arduino stuff? I am on Marlin 1.1.8. Can I load anyone's A10M config? Is the official Geeetech files 1.1.19 or 2.0?
Thanks in advance
Post by William » Mon Feb 17, 2020 8:54 am
Hi,if your firmware is fine, it is not recommended to update.
Chub
Post by Chub » Mon Feb 17, 2020 9:31 am
Thank you for the advice. That's why I have dragged my feet on upgrading.
I suddenly am getting huge layer shift after like 5 layers. I have checked belts, bolts for tightness. All seems good. I figured if I had to adjust stuff, I might as well upgrade. I will keep 1.1.8 for now.
Thoughts on layer shift after multiple layers are successful? All was good, them BAM.
johnowen
Post by johnowen » Thu Sep 09, 2021 12:39 pm
I am really frustrated with this. Every time I tried but was unable to download it via CURA. I have checked thoroughly https://www.exactlly.com/blog/index.php ... -benefits/ but was unable to download it. Can anyone from here please tell me where the issues are?
tariv
Post by tariv » Mon Sep 20, 2021 4:36 pm
Query here is about the way to update the HEX firm ware via the Cura in the year 2019 in the month of December. The complete method is given below with the step wise process to make the redbubble design with the memory that has used by these.
kelun
Post by kelun » Fri Sep 24, 2021 8:53 pm
I like to read out the blog whenever I get free. I actually like the blog and ideas that you have mentioned in it on Garden Screening here you can read out the difficulties of the people and then write a blog on it too.
tozeha
Post by tozeha » Tue Oct 26, 2021 4:46 pm
3d printers are too useful as they present the relevant information that is necessary for us. According to the various details, lock installation you will be able to join the essential data that will be helpful in it.
