I3 pro B firmware
Zolric
I3 pro B firmware
Post by Zolric » Sat Jan 18, 2020 10:16 am
I'm a little afraid, I probably should to calibrate my printer I3 pro B. But in the firmware topic there is to much or not enough informations...
Which firmware should I use :
Marlin? Ramps? Sanguin ? 3d touch...?
Should I check my threaded rod and modify the source code? How to know my rod...
Should I send a gcode to the printer at the end? And how?
Should I use Marlin 2.0???
There is to many questions to be confident...
Re: I3 pro B firmware
Post by William » Sat Jan 18, 2020 10:37 am
:D Hi, Is there something wrong with your firmware?
If you upload the firmware,
You can download it on the official website: https://www.geeetech.com/download.html?download_id=34
Then you can refer to this for uploading: viewtopic.php?f=20&t=69684
Zolric
Post by Zolric » Sat Jan 18, 2020 3:22 pm
Thank you.
I had to change the power of the motor specially for z axis...
So I am trying my first printing with the calibration cube and I find some adjustments to do...
And also I have to understand why the printer has some difficulty to finish like the extruder don't have the strength to pull the plastic...
