Post
by Sodium100mg » Wed Feb 26, 2020 3:55 pm
I'm new to 3d and I find simplify3d to be very easy to use and produces good output, but at the end of the day, 3d printing will always be a mix of technology and voodoo magic. The best I can hope for is to dial in a set of settings, then never change them.
For small detailed work, a resin might be better, but whatever way you go, simplify3d might still be a good choice. Resin of filament, the object still will need structure to build off of, in order to start printing an elbow connected to nothing, but the structure. I watch the instructional videos and see people with years of experience still have prints go bad. I might have gone resin, except for the smell.
Simplify3d has worked very well at creating stuctures that break away easy and leave little trace, but try to print small fingers by the structure can cause issues. The software has provisions for more material at the top of the structure, which allows a separate extruder to form the top layer, which can be a soluble filament that can soak for hours and disappear. Using dual extruders, the unused extruder can drop, which a 2 into 1 or a 2 into 1 has filament mixing and requires a prime pillar, where the prime pillar can use more filament than the object. Filling the bed with objects can share 1 prime tower.
Simplify3d makes the structures removable enough that except for internal structures that I want to remove, a 1 color would work well enough for my needs. Swapping between the PLA filament and the soluble filament is a slow and more expensive.
