Pro i3 B - Extruder has stopped working
RobX
Post by RobX » Thu Mar 21, 2019 5:01 am
I've had my printer for a year and it's been great - thanks for making such a good value product. :) but it stopped extruding yesterday. I've followed all the advice I can find here and have:
- installed the latest firmware,
- confirmed all motors and drivers boards are OK by swapping X and extruder cables and drivers.
So I can only think that the GT2560 board has maybe failed...? If it's just the output for extruder #1 that's dead, could I use the output for extruder #2 instead? If so, what changes would I need to make in the firmware? Any other ideas?
Xie xie. :)
Re: Pro i3 B - Extruder has stopped working
Post by William » Thu Mar 21, 2019 10:02 am
You can refer to this post then swap the pin define to E0 and E1.
http://www.geeetech.com/forum/viewtopic ... 20&t=18020
RobX
Post by RobX » Sat Mar 23, 2019 6:45 am
Thank you. It turned out there wasn't a fault - but the link told me the extruder won't run under 170C, which helped.
