extruder not pulling enough filament
Re: extruder not pulling enough filament
Post by William » Mon Apr 02, 2018 8:05 pm
gambum wrote:
Fri Mar 30, 2018 9:34 pm
I tried removing the plastic but I may have removed too much of it. Can you provide the .stl files of the mount? Are they available somewhere for download?
We need more details of it.
Which part?Could you upload a picture of it?
3dw
Post by 3dw » Mon Jun 04, 2018 2:33 am
[quote=William post_id=34475 time=1480757103 user_id=51382]
@websmr
Great idea...But i'm afraid it can't last too long...
[/quote]
Another option is to take a screw with a rounded head about 1/4in / 10-15mm and invert it and insert into the spring. This will be a more permanent solution. I had the same problem and this seems to be working.
ricky007
Post by ricky007 » Tue Jan 01, 2019 12:59 am
Hi all
I also have the problem where there are layers missing in the print
After much blue air and trials and testing I can summarise
I have calibrated the extruder and is extending at 102 % (programmed 100mm of movement/actual movement of 102mm)
It isn't spring pressure as when you inspect the filament teeth marks are present whereas if the pressure wasn't enough I'd expect to see gouging of the filament where the drive wheel continues to rotate against the filament
Removing the fan and heatsink and fixing the drive assembly in place with shorter screws I see that the drive wheel is jumping back. This is random, I can be 4mm off of the bed or 30mm off of the bed, it can be a few jumps or 2 layers.
I increased the voltage to 1.1 volts and this appeared to work even when increasing the feed rates to 400%
All this time I was running without the fan and started another model.
Dang blast it the jumping was present, worse than ever. The extruder motor was rather warm though so I've replaced the heatsink and fan and I'm letting it cool down as well as myself before I try again.
I figure to leave it until tomorrow so that I can spend at least a little of the Christmas break with my family!
I'll let you know how it goes
Post by William » Wed Jan 02, 2019 9:03 am
Hi all
Could you tell us the printer of yours?
i3?A30?E180?a10 or A20?
ricky007
Post by ricky007 » Sun Feb 03, 2019 2:20 pm
Sorry William, I missed this!
Geeetech I3 Pro B
Post by William » Wed Feb 13, 2019 1:17 pm
How is it going on?
Have you try to clean the hotend and adjust the extruder feeder?
Dr_Schmal
Post by Dr_Schmal » Sat Feb 16, 2019 4:20 pm
I had the same problem. I removed the golden cooling part of the extruder, it runs only with fan. Finally there was No clicking sound and it works! :D If somebody has the same proble, try this. I think the feeding stepper stuck in the cooling part. :ugeek:
PS: dont screw the fan to tight to the feeder :idea:
Dr_Schmal
Post by Dr_Schmal » Sun Feb 17, 2019 6:20 pm
If you remove the cooling part, it will print at layer height of 0.2 mm or smaller, but at 0.3 mm it is still skipping :x
Post by William » Mon Feb 18, 2019 9:23 am
Hi,Schmal
You can refer to these:
1.Check the temp of the hotend at first,try to up it to 220C(For PLA)
2.Check the nozzle diameter setting from slice software
3.Try to check the hotend clogged or not,you can use the ejector pin clean it
:D
Scenator
Post by Scenator » Sat Apr 06, 2019 12:25 am
I've got a similar problem:
for the first 2..4 layers my extruder is working corectly, but suddenly, at first less and then no filament is comming out.
When I push the filament in the extruder, I can push the filament for 10..20 mm with no resistance and then - with resistance - the filament is comming out normal.
I have changed the nozle, cleaned all extruder items, used other filament (PLA/ABS) but it is still the same.
Any ideas?
Best Regeads in advance
