In this video, you will see how to tear the mk8 extruder down, and how to replace new extruder kits.
https://www.youtube.com/watch?v=aPvVUZQnOMM
How to replace extruder thermistor:
https://www.youtube.com/watch?v=FR0n2FHrjmc
How to replace nozzle:
https://www.youtube.com/watch?v=t2tUxrZDi8o
How to level dual extruder:
https://www.youtube.com/watch?v=XGpcueI ... e=youtu.be
Videos of MK8 Extruder assembly
Re: Videos of MK8 Extruder assembly
hello the heater and the thermistor move inside the hole out and in, can be fixed someway?
there's a setscrew for the heating cartridge, did you see that? and you can use a cable tie to tie them up.
Hello there is a small hex screw next to the hole in the back but I tryed to turn clockwise the screw go inside the hole a lot but don't fix. Should I turn a lot more?
I remember the setscrew is side of the heating block not in the back, maybe you need to remove the sponge thing to check it, and you can screw it a little tight.
- QQ截图20151125155347.jpg (67.11 KiB) Viewed 23963 times
is side of the heating block not in the back, maybe you need to remove the sponge thing to check it, and you can screw it a little tight.zhangxueyou wrote: ↑Fri May 29, 2015 10:35 amIn this video, you will see how to tear the mk8 extruder down, Audacity Find My iPhone Origin and how to replace new extruder kits.
