Geetech Prusa i3 Pro A - Z Axis Problem!!
johngomes
Post by johngomes » Sat Oct 26, 2019 5:03 am
Hello
I'm having problems with my Z Axis. It seems that sometimes one of the two motors is "stuck" and then only one of them moves,
so everything is getting messed up.
after a 10mm height of printing I measured the difference between the two motors and it reached up to 3mm.
By Stuck I mean that I hear like a weird clicking noise, it tries to rotate but not successful.
I did check the height of each motor at start (Home position) and it's the same position (0.1mm resolution caliper).
Help???fedloan irs.gov easybib
Re: Geetech Prusa i3 Pro A - Z Axis Problem!!
Post by William » Sat Oct 26, 2019 9:24 am
:D Hi,If you are referring to one of the z-axis motors being stuck,
You can check if your z-axis is at the same level;
Whether the coupling is installed correctly;
Whether the brass nut is too tightly installed can be adjusted properly;
For details, you can refer to this: http://geeetech.com/forum/viewtopic.php?f=82&t=60931
If it means that the motor can't work,
You can try to swap the motor wires of other axes with the motor wires that cannot run.
Determine if the motor line is broken.
BumblingBee
Post by BumblingBee » Wed Mar 04, 2020 3:05 pm
Thanks for the great feedback.
pelysyd
Post by pelysyd » Tue Mar 23, 2021 3:04 pm
Geeetech Prusa i3 Pro 3D printers model is facing issues on their axis. The company analyzed the problem and got the people are facing the issues on the settlement of the axis on bestessays.com.au here you can read about it and the report the committee has been issued.
