on all 3 axis, x y and z, stop switches don't stop the travel. The carriage will hit the stop, vibrate as it tries to travel farther, finally give up, back ooff a little, and then hit it again and stop. So it acts as if the stop switch needs to be pressed twice to actually stop.
Please help as soon as possible.
Scott
Re: stop switches don't stop the travel
Please change the relevant values in firmware file "configuration.h":
const bool X_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool Y_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool Z_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool X_MAX_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool Y_MAX_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool Z_MAX_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
Please reverse the value.
How do I edit that file?
Do you have firmware files? If you don't have, please tell me your mainboard type, and your printer type. I will send you the firmware.
Select all the files(Ctrl+A) and drag them into Arduino IDE 1.0.1, jump to "configuration.h", and find the codes I sent you before. Reverse the values.
Click Verify(icon"√"), if display "Done compling", then click Upload (icon"→“).
8mm acrylic I3B with the singuinolou board
Thank you
Thank you
no to having firmware files
I have the 8mm I3B with the singuilo board
no, I do not have the firmware files
I have the 8mm I# I3B with the singuilolo board.
Thank you
Thank you
I3B sangino board
Thank you
I3B sangino board
Thank you
