3d touch i3 pro b firmware compiling error
digits
Post by digits » Tue Feb 20, 2018 7:33 am
hi i have just fitted the 3d touch to my i3 pro b with gt2560 board, i found the firmware on this site but when i try and compile it i get this error
'error'
using typedef-name 'fpos_t' after 'struct'
here is the full error report
Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
from sketch\BlinkM.cpp:5:
#define X_MAX_PIN -1
#define X_MAX_PIN 24
#define Y_MAX_PIN -1
#define Y_MAX_PIN 28
from sketch\ConfigurationStore.cpp:1:
from sketch\MarlinSerial.cpp:23:
sketch\Marlin_main.cpp:2667:36: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
from sketch\cardreader.h:8,
struct fpos_t {
c:\program files (x86)\arduino\hardware\tools\avr\avr\include\stdio.h:950:33: note: 'fpos_t' has a previous declaration here
sketch\Marlin_main.cpp: In function 'void set_bed_level_equation_lsq(double*)':
sketch\Marlin_main.cpp:998:36: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
planeNormal.debug("planeNormal");
exit status 1
Re: 3d touch i3 pro b firmware compiling error
Post by William » Mon Feb 26, 2018 4:17 pm
You should upload the firmware via Arduino 1.0.1
boomer
Post by boomer » Sat Mar 10, 2018 12:42 pm
I tried uploading to 1.0 and I still have an error as well.
Post by William » Mon Mar 12, 2018 7:10 pm
"fpos_t" error seems because the latest Arduino version have more strict definition of the firmware
