upload Arduino Mini 328
schrist
Post by schrist » Fri Apr 06, 2012 5:15 pm
I try to upload this brick, but unsuccessful..
I've connected RX and TX, Groun and 5V. The same cable is used to upload a Mini 168 successful.
What are you meaning ?
I use the latest version of Arduino (1.0), choice the mini board with 328.
techsupport
Re: upload Arduino Mini 328
Post by techsupport » Sat Apr 07, 2012 2:40 pm
Hi friend;
Please press and hold the reset button on board,press upload in the IDE. As soon as the Led on the converter flicker, release the reset button.
Email: forum@geeetech.com
schrist
Post by schrist » Sat Apr 07, 2012 2:53 pm
Hi dear friend,
I've tried. I am not using an USB converter. I use the serial port with a MAX232 to convert rs232 to 5V.
I press the reset button and release when a message (in white) appear on the bottom screen.
But unsuccessful.
The same operation is fine with a 168.
Best regards.
techsupport
Post by techsupport » Wed Apr 11, 2012 4:36 pm
Hi Schrist,
please use a USB converter to program it, and detect if it's your serial port problem or the mini328,
we test all the items before shipping,
Thanks,
schrist
Post by schrist » Wed Apr 11, 2012 6:09 pm
Sorry, I did not have an USB converter....
Best regards
schrist
Post by schrist » Thu Apr 12, 2012 11:59 pm
My serial port run fine:
when I change the module328 with a 168 in the same soket, upload run fine...
best regards.
schrist
Post by schrist » Fri Apr 20, 2012 2:05 am
No Answer ?
I've found the problem: just connect a Led on the 13 pin. The Led blink always at a frequency of 0.5Hz.....
Did you understand ?
I understand that there is no bootloader. It is right ?
If yes, how to burn bootloader ?
Regards
Sébastien
jack
Post by jack » Fri Apr 20, 2012 5:19 pm
Hi, friend;
Sorry for late, the bootloader must be burned onto it in advance, we will offer you another one.
Regards;
Jack
schrist
Post by schrist » Fri Apr 20, 2012 6:09 pm
I just found an AVR device (ISP) and burn the bootloader.
I can load my sketch ! (on the two devices).
I've another problem: with the arduino 23 the loading process run fine.
But with the last arduino IDE 1.0, I become an error message that the sigature of device is bad (try -F to override). I did not understand. Have you an idea ?
Regards.
Sébastien
jack
Post by jack » Tue Apr 24, 2012 5:51 pm
Hi friend,
In some place, Arduino IDE 1.0 is not compatible with early version. Generally, we suggest our customer using IDE V22 for reliablity
regards,
Jack
