Rostock g2 lcd screen lockedup/ MINTEMP error
qmehling
Post by qmehling » Wed Apr 20, 2016 1:02 am
Hey guys hope you can help me out.
Yesterday I was testing and calibrating the unit after firmware update install. I tested the bed and hot end heats to make sure things were up to par when the power went out due to high winds. Now when I power on the unit or connect via USB, the LCD is locked up and I cannot connect via Arduino.
Using OS 10.6, The system profiler isn't showing it in the Device manager anymore either.
Re: Rostock g2 lcd screen lockedup/ MINTEMP error
Post by Mark » Wed Apr 20, 2016 5:09 pm
maybe the board is damaged during the power problem, regarding to the temp errors, you can check out this link to see if the board is damaged or not:
http://www.geeetech.com/forum/viewtopic ... 23&t=17030
qmehling
Post by qmehling » Thu Apr 21, 2016 12:29 am
Hot plate and hot end thermistor showing as open/ bad
Power supply I get 10.89Vdc on both legs.
USB LED is on
Heat bed and Hot end LED is on
4.99Vdc at the spot near the MOSFET
Hot bed and Hot end fuse I get 10.88Vdc, both sides.
MOSFET #2 leg is 9.6Vdc
MOSFET #1 is .5 maVdc
Looks like I need to order thermistor's and power supply, possible new board?
Post by Mark » Thu Apr 21, 2016 4:33 pm
yeah I think you need both of them..
qmehling
Post by qmehling » Thu Apr 21, 2016 4:41 pm
I went ahead and ordered replacement parts. Power supply, PSU and thermistors.
I did however adjust the trim pot on power supply, I get 11.1Vdc now. I figured the board would be bad since the LCD wasn't responding. Hopefully this will be a simple plug and play. Thanks for the help.
qmehling
Post by qmehling » Tue May 03, 2016 11:33 pm
Parts came in and replaced. No errors until i tried to home out. Z tower would be only axis to move during home command. I could move each axis separately without a problem. I reinstall firmware and now I have 'MINTEMP" error again.
qmehling
Post by qmehling » Wed May 04, 2016 12:28 am
On initial startup after replacing Board, It said "Ultimaker". Z tower would home out hard while the other towers wouldn't move. All three axis would move independently until the home all. I re-installed firmware from your site, now shows "mintemp" error just like it did with the other board after firmware re-install. Am I needing to change PID settings or other setting related to thermistor?
in Repetier-Host Mac
< 11:17:12 AM: echo: External Reset
< 11:17:12 AM: Marlin 1.0.3 dev
< 11:17:12 AM: echo: Last Updated: May 3 2016 10:46:19 | Author: (Hogan, Delta)
< 11:17:12 AM: Compiled: May 3 2016
< 11:17:12 AM: echo: Free Memory: 3504 PlannerBufferBytes: 1232
< 11:17:12 AM: echo:Hardcoded Default Settings Loaded
< 11:17:12 AM: echo:Steps per unit:
< 11:17:12 AM: echo: M92 X80.00 Y80.00 Z80.00 E93.00
< 11:17:12 AM: echo:Maximum feedrates (mm/s):
< 11:17:12 AM: echo: M203 X400.00 Y400.00 Z400.00 E45.00
< 11:17:12 AM: echo:Maximum Acceleration (mm/s2):
< 11:17:12 AM: echo: M201 X5000 Y5000 Z5000 E5000
< 11:17:12 AM: echo:Accelerations: P=printing, R=retract and T=travel
< 11:17:12 AM: echo: M204 P1000.00 R2000.00 T2000.00
< 11:17:12 AM: echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
< 11:17:12 AM: echo: M205 S0.00 T0.00 B20000 X20.00 Z20.00 E5.00
< 11:17:12 AM: echo:Home offset (mm):
< 11:17:12 AM: echo: M206 X0.00 Y0.00 Z0.00
< 11:17:12 AM: echo:Endstop adjustment (mm):
< 11:17:12 AM: echo: M666 X0.00 Y0.00 Z0.00
< 11:17:12 AM: echo:Delta settings: L=delta_diagonal_rod, R=delta_radius, S=delta_segments_per_second
< 11:17:12 AM: echo: M665 L196.00 R92.00 S200.00
< 11:17:12 AM: echo:Material heatup parameters:
< 11:17:12 AM: echo: M145 M0 H190 B55 F255
< 11:17:12 AM: echo: M145 M1 H230 B70 F255
< 11:17:12 AM: echo:PID settings:
< 11:17:12 AM: echo: M301 P22.20 I1.08 D114.00 C1.00
< 11:17:12 AM: echo:Filament settings: Disabled
< 11:17:12 AM: echo:Z-Probe Offset (mm):
< 11:17:12 AM: echo: M851 Z-2.00
< 11:17:14 AM: Error:MINTEMP triggered, system stopped! Heater_ID: 0
< 11:17:14 AM: Error:Printer halted. kill() called!
qmehling
Post by qmehling » Wed May 04, 2016 12:42 am
this is the code from the firmware I installed as is:
* Temp Sensor defines
#if TEMP_SENSOR_0 == -2
#define HEATER_0_USES_MAX6675
#elif TEMP_SENSOR_0 == -1
#define HEATER_0_USES_AD595
#elif TEMP_SENSOR_0 == 0
#undef HEATER_0_MINTEMP
#undef HEATER_0_MAXTEMP
#elif TEMP_SENSOR_0 > 0
#define THERMISTORHEATER_0 TEMP_SENSOR_0
#define HEATER_0_USES_THERMISTOR
#endif
#if TEMP_SENSOR_1 == -1
#define HEATER_1_USES_AD595
#elif TEMP_SENSOR_1 == 0
#undef HEATER_1_MINTEMP
#undef HEATER_1_MAXTEMP
#elif TEMP_SENSOR_1 > 0
#define THERMISTORHEATER_1 TEMP_SENSOR_1
#define HEATER_1_USES_THERMISTOR
#endif
#if TEMP_SENSOR_2 == -1
#define HEATER_2_USES_AD595
#elif TEMP_SENSOR_2 == 0
#undef HEATER_2_MINTEMP
#undef HEATER_2_MAXTEMP
#elif TEMP_SENSOR_2 > 0
#define THERMISTORHEATER_2 TEMP_SENSOR_2
#define HEATER_2_USES_THERMISTOR
#endif
#if TEMP_SENSOR_3 == -1
#define HEATER_3_USES_AD595
#elif TEMP_SENSOR_3 == 0
#undef HEATER_3_MINTEMP
#undef HEATER_3_MAXTEMP
#elif TEMP_SENSOR_3 > 0
#define THERMISTORHEATER_3 TEMP_SENSOR_3
#define HEATER_3_USES_THERMISTOR
#endif
#if TEMP_SENSOR_BED == -1
#define BED_USES_AD595
#elif TEMP_SENSOR_BED == 0
#undef BED_MINTEMP
#undef BED_MAXTEMP
#elif TEMP_SENSOR_BED > 0
#define THERMISTORBED TEMP_SENSOR_BED
#define BED_USES_THERMISTOR
#endif
qmehling
Post by qmehling » Wed May 04, 2016 1:29 pm
all is good, I resolved my situation. i moved the hotbed thermistor to the farthest away from the reset button (extruder 1) reset board, got a "MINBEDTEMP". I then replaced both thermistors and reset, reconnected to repetier and powered up. Now display says "Delta G2 Ready", unit homes out, heats up correctly. Going to calibrate later on tonight.
Thanks to Icarusfacto's post.
